Ajohnson85's '87 build
Happy birthday to me
42" radius, 5w osram led, 400w total, 40k lumens
TG stud eliminator, rear axle hung ready to set pinion axle.
Here is what has kept me busy for the last month, gotta keep the DD lookin good
Ok but seriously, how's that stud eliminator kit work? If those aren't studs, how on earth are you supposed to tighten them with the dropout in the way?
Lol, yea it's still just a 2wd til I get the 4Runner operating.
Those are button head bolts, and they are not very fun to install from the inside. It took me about 2 hours because a ratchet won't fit in there. One option is to install the bottom 2 on the diff from the outside, they can be used as drain holes when you shave the drain plug. I'm going to see how long a lo pro plug lasts though.
Cleaned up the shocks and mounted the rears. I really like the LROR upper mount. Those are LROR lower mounts too, mounted up high on the top side of the axle tube
Good progress! How far is the front hanger hanging off the frame? With the TG springs, how far forward from stock does it move the axle?
I moved the hanger all the way forward as one would with RUF, then I moved the shackle tubes forward for the TG spring length. I think the TG setup is 1" forward from stock, and mine is probably close to 2" now.
DionicioLives
