AKYota Trailer Build
psraff
So I picked up a trailer for $300, to start my Camping Trailer. At first I thought it was an old M100, but that didn't match up so I thought it a Bantam TC-3.... Nope. Emailed the Bantam website and they said it could be a Sterling Trailer. For all I know it's an old Sears and Roebuck Trailer.
20180817_200426 by psraff, on Flickr
20180817_200434 by psraff, on Flickr
First to identify everything that should be worked on... Yep, pretty much everything.
I count 7 leafs on it. Six lug hubs which needs work. I plan on getting new leafs and axle/hubs.
20180821_083409 by psraff, on Flickr
Jack doesn't work. Very old hitch and the tongue has been rebuilt once already.
20180821_124423 by psraff, on Flickr
Shelving brackets to hold the tail lights.
20180821_124444 by psraff, on Flickr
Tailgate works, but pretty bent up.
20180821_124501 by psraff, on Flickr
First thing I did was cut off everything I didn't need to give me a solid base to start with. Took the pressure washer to it get as much paint off of it as possible.
Then I welded up all the bolt holes that was in the tub.
Picked up some steel and started to work on the sides some. I wanted to have it high enough so I can get a ARB (or other) fridge into it so it would be an inside height of 22".
20180826_140827 by psraff, on Flickr
20180826_140816 by psraff, on Flickr
This gap is where I'll have a door into the side and the cooler \ fridge will slide out on rails.
20180826_140805 by psraff, on Flickr
I have enough steel left over to finish the railing but I have to get ready to leave for work.
20180826_140900 by psraff, on Flickr
I plan on cutting the door off and all it's hardware and making a new one. I'll have it recessed even with the back of the trailer secured with bullet hinges swinging out to the side.
Tasks to work on:
1. Finish the side framing.
2. Cut siding for the new sides (I've got 16 awg sidewalls from an MCC that will work great).
3. Make back door.
4. Frame in for the back door.
5. Frame and fill the front section from the rear.
6. Make back bumper
a. Cut in hitch reciever
b. Mount Bumper, reenforce frame
7. Rebuild tongue.
8. Build tongue mounted storage box.
9. Slide out for Fridge.
10. Slide out for Main Section.
11. Build Frame for Fridge Door.
12. Build Door for Fridge Access.
13. Electrical Center.
14. Solar Panel mount.
15. Stereo and Speakers.
16. Lights.
17. New Axle\Suspension.
18. Frame in the Top.
19. Lay skin for the top.
20...More To Be Added.
fhgy0045
