Aligment after toytec 3" lift + JDA arms
thanks for the help everyone. Did the fender and mod and all is good.
Will let it settle for a couple hundred miles and take it in after i install a DS 1/4" plate if needed, this time asking for higher caster.
Like I said, I would get it fixed up. Alignment has two parts. One is being in range of what is acceptable for both sides. The second is matching the alignment on both sides. This is the exact reason why u get someone that knows what they're doing. So yeah, I disagree with mrblahs statement. I don't half ass anything on my truck including alignment.
You don't understand caster... It's OK for caster to be different side to side within reason. Has nothing to do with tire wear. Read my post about road crown. It is somewhat standard procedure to set the two sides different depending on who you talk to.
Finally finished
Toytec 3" lift, JBA UCA's, Cooper STT pro 285/70/17, Vision Fury Offroad 17 x 8.5 0offset
youngrk
