Alignment after replacing UBJ?
cbr900boy
Hey guys, was wondering if I need to get an alignment after replacing my upper ball joints? I know inner and outer tierods for sure but UBJ? By just looking it the UBJ shouldn't change the geometry of the front end, however I would like to know what others have done. I did do a search and nothing came up. Thanks guys.
If you had an alignment done with a sloppy UBJ then yeah you would need an alignment.
Changing upper ball joints might affect your camber slightly. But it should be very minimal. Realistically it should have no affect on caster/ foot and toe. Are there any other front end parts you could replace? Any shop would tell you to get it aligned after replacing the ubjs, but I would want to do more front end work if necessary to make paying for an alignment worth while. I changed my shocks/struts over a month ago, lifting my front end another inch, and I know that affected my caster and camber. But Im not paying for an alignment until I finish the rest of the front end work I need to do
AndiGarage
