alignment issues after 3" lift
kjeisner
I put on the Bilstein 5100s with Eibach springs, but I cant get the alighnment right after taking the truck to several places, I cant get rid of to much positive camber. Any one else having this issue, i despritly need to get this fixed my tires are getting ruined.
If its more than 3" inches you will have issues. Are those adjustable? I think you can move the lower plate down on the bilstins. You should try a lower setting. If you stuck on that much lift. Buy some UCA's Total chaos, camburg, light racing ect. THey fix camber issues
Im also running total chaos uca's
Post your alignment specs
Here are mine with 4 inches+ of lift and stock UCA's
I had two of my cam adjusters seize. The techs never told me about them. They would always "get it as close as they can". Upon further review, during some other repairs I was doing I found the seized cams. I'm running about 3.5" of lift and my alignment is dead on.
Ask and see if they are having issues moving some adjustments.
Ambrose67
