Alignment issues! Truck cannot get non positive camber.
I missed the adjustable uppers but they should have a close to stock setting if not lifted...if they are the SPC they should have a diagram on where to put it to keep it close.
I’m equally confused. There is no lift on the vehicle yet serious alignment issues. I have adjustable control arms up top so at this point I’m not sure if the alignment shop is just garbage and really shitty at their job, could be the case, or I’ve got fear damage pushing my alignment so out of whack no shop can fix it. Thing is, I’ve only ever had tiny fender benders that barely dented the front bumper.
This is my third alignment shop that’s basically jut not able to get it to 0 camber, 0 toe, 3 degrees of caster like I asked. Obviously I’m not the tech and am just going off what I’ve been told.
At this point, I am considering taking it to a Toyota dealer, or just throwing $300 at a 4 Wheel Parts store near by for a custom alignment to get it to the right specs as I just don’t believe I’m all the way out of adjustments and cannot get to zero.
My bad. I assumed the truck was lifted somehow. I just don't understand how people can make 32s fit under a stock vehicle. Well, the only thing left then is incompetence. They did change the specs too. Probably to deceive you. Run from that shop.
OP some good advice being offered here! But I have to agree that NO QUALIFIED TECH should worried about camber affecting toe. Although the toe will change when camber is moved, camber is not affected by adjusting toe(unless you had to move it 5 inches).
I agree that this alignment shop is not great. The shop doing the actual labor of replacing parts agrees the alignment shops word seems wrong. I’m going to try 4wheel parts in Oakland out on Monday. Alignment there will set me back $300 but they at least are used to working on 4x4s and trucks with modifications.
I’m hopeful they can get me squared away. It’s damn near impossible to find a trustworthy alignment shop out here.
Agreed I’m running the hell away. Truck actually does sit higher than a normal 99 would stock, but not by much and is mostly due to the 32s.
Im hopeful the dedicated 4x4 place will get my rig squared away but at this point I’m not confident in any place.
Update: no more issues
Finally got the truck into a dedicated 4x4 shop and they got it aligned perfectly. Truck drives like brand new and tracks straight as an arrow. I’ll post the sheet later needless to say I’m thrilled to have a truck that drives normally again.
That's great to hear, sad that it took several tries to get it right...are the specs the same left and right, lol!!
Yup, camber and toe look identical, .2 degrees difference in caster. One of the shops even offered to give my money back after a negative review
Been a while, but was wondering if you remember what the shop said the issue was. Was it just incompetence?
Neither myself nor a couple reputable shops in town can get my camber down. As a result my front tires are done within a year. I am lifted on 32's. Was considering buying SPC's to replace my JBA's and see if I could adjust them for camber.
The reason why the alignment techs can't dial in your camber and caster could be because your cam adjusters are frozen inside the bushing sleeves. It's VERY common. But, the only way you can figure out if they are frozen from corrosion inside the bushing sleeve is you take the bolts out and then try to remove the cam adjusters. My bet is you have some frozen cam adjusters.
These two videos will help you out with the process. The first video covers most of the job. The second video shows how to cut out frozen cam adjusters so you can remove the control arms and also shows a way to get the bushings out using a press rather than the bottle jack technique shown in Part 1.
t
No problem. Hope what I suggested ends up being the fix.
I watched both parts. I was hoping I'd be able to leave most of the suspension nuts/bolts in. When putting in a lift and lbj's, I remember using 3-4 days of my vacation. UCA's took a full day. This job here, maybe two more precious days off. Mine is not too rusted, things just get old and stubborn.
Toyota wanted a couple thousand to align the vehicle. They said all adjustment points were frozen stuck. I managed to fix the toe using a torch. I think I kept their invoice as a souvenir.
Happy 4th.
johnnya
