Alignment needed? Sanity check
mavrick1903
So, I went through the process of changing the following parts based on needs.
UCA Bushings
Steering knuckle
caliper/rotor
lower ball joint
wheel bearing
Do I need an alignment? Swapping the steering knuckle and lower ball are the only reasons I can think that I do, but at the same time, those should not affect the alignment... right?
Yes. Messing with the UCA, new knuckle and wheel bearing you "might" not have changed geometry that much, but I certainly would.
