Hello Guys,
I'll be installing Bilstein 5100s all around. Front set at 1.75, rear with 1 inch spacer. Did not get aftermarket UCA because I read on here that it's not needed if it's under 2.5 inches of lift. I searched this forum for alignment specs and everyone seems to go with as much caster as the alignment shop can get while keeping all other areas of alignment within factory specs.
Is there a reason for increasing caster compared to factory caster specs? Should I be asking for "as much caster as possible" or is there a specific magic number?
I just want even tire wear, no wandering, drives straight. Thanks!
