alignment sheet
ryan87
first is my first alignment and i had a pull to the right.. i was told it was caused by uneven caster
went today to realign and they gave me uneven caster as well although the other way and told me thats not enough uneven caster to cause a pull.
after this it still pulls right. will change lanes and usually go from left side of street to the right so i know its not road crown. he said he will redo it friday and make them even but it will not fix my issue, they even croos rotated my tires.
what do you guys think needs to be done
Any suggestion before heading back to the alognment sheet? Or should I just deal with it since it's very slight pull..also will a pull always cause tire wear or not necessarily? Iv been stressing and researching this for days since I just got new tires I don't want to ruin them
It depends on the tech working and the equipment. Is yours lifted? The numbers looks pretty good.
I would see if they can get them even on both side. The little more caster will not cause uneven tire wear. The toe and camber will cause uneven tire wear.
I would see if they could get the toe to positive .02 / .03 both sides. It looks like the old numbers on the toe could have been the problem,
Bobby
Your old toe was way out before at negative 40. That would cause uneven tire wear. Should be fine now just rotate your tires and keep an eye on it.
Bobby
the -40 was after installing uca's then i had it aligned which is the first picture shows before and after, it pulled slightly right so i took it elsewhere and had it redone (on the hunter, second picture) and still getting pull to the right even after crossing front tires..i removed wheel spacers today because thats the only other thing i have added that i could think it can be(i dont see how if it was aligned with them). will find out later to day
