Bala de Plata
Being that I finally had my truck back, I was able to install these last night. Took longer than I expected and as with most things, would have helped to have someone assist. The arms are nice and beefy, and if I can be bit of a wuss, I dont like the color, the gold and red are a little weird in my opinion. Moving on, the first thing I did was jack at the axle and removed wheels. Thne I jacked it up a bit more and placed stands just in front for the lower arm mounts. Then I let the axle droop a bit and put stands on the axle to keep it level. I then removed the stock (undamaged) arm on the driverside. Yeah, the one nice and tucked up behind the gas tank. That was fun, having a set of ratched box wrenches helps in the tight spots but it still took a few minutes to get this one removed. I took out the bolt closest to the axle first, beware depending on the location of your axle to frame there may be a bit of spring in them, so watch your hands and fingers. Then I took this arm and used it to measure and base the spread on the all pro's. These are a bit cumbersome to get just right. They are countered threaded to each other which should have helped, but it was still a bit difficult. Installed the all pro on the driver side then removed the passeger stock arm and then installed the other all pro arm. This side was much easier as there was nothing in the way. I think it is important to note to not take off both arms at the same time either. Go one at a time to limit any possibility of axle movement with both off. Also, it was a bit tricky to get them lined up. I had to add a rotation on one side to aid in this. I played with raisin/lowerin both the axle and frame and was not able to get them lined up perferct and ended up using a screwdriver to kinda force them into postion. Overall, they have some nice flew after install and a bit of rotation. Driving today onroad there was not a huge difference in any feel. Didnt feel like I was getting any road noise or vibration transfer to the frame. But time will tell and I will continue to post up my findings.
And here's the pics
Jacked and supported
Stock arm used to measure offset for the All Pro's
And the installed shots, I was in a funky position when I took the photos. Looks a bit unlevel but just the pic
And here's the pics
