am i getting jipped?
4runna08
my 4runner has a 114000 miles so i know its due for a timing belt . my mechanic wants to charge me $40 to "check" what work needs to be done for the timeing belt. is this reasonable?
Why don't you ask around, and see what/if people are charging to check. If they all charge about the same, then it's reasonable. If they don't charge, then no it's not reasonable.
But if I remember correctly they need to be changed at 90K miles, so you shouldn't need a check, you need it replaced. When you go in, don't say you want your belt checked, say you want it replaced.
You shouldn't wait for something like that until it fails, you should replace it before it fails. Yeah, you can go 120K miles or more on it, but they recommend you do it at 90K miles so you prevent any damage caused by it failing.
Only way I may say OK to that is if he's somebody you've been with for a while, trust, etc and he agrees to refund the $40 when he does it. If he has a "Mom & Pop" place that doesn't do a lot of 4.7L Toyotas he probably wants to review the process online (for which he has to pay). If unfamiliar I can see it taking an honest 30 minutes to come up with an accurate quote.
:cheers:
044runner4
