American made D-ring trailer hitch receiver
Factor 55 + the crosby shackle. that's what I have on all the time. I don't bother to take it off. I have the factor 55 lock pin as well
The ball is a bad idea. They are not strong enough and the leverage in single shear is a big problem for low quality hitch balls. They also make a pretty dangerous projectile.
The hitch pin is perfectly fine. It's the most common way to do it. You'd need to be north of 100,000 lbs of force to break a hitch pin. If you wanted to really go crazy you could cut a 2" piece of 1.125x.857 DOM and make a sleeve for the hitch pin. It's not necessary or useful in real life, but it would increase the theoretical strength of the assembly.
If you're looking for more farkle - the stinger with a shackle is great. I haven't done the math, but I'm pretty sure the aluminum ones are weaker than a hitch pin attachment. A steel one is probably stronger. But it's all academic. You won't break any of them. They're all perfectly fine for the forces involved. You won't cut the strap. I've done this hundreds of times from every angle as have thousands of others. Straps are hard to cut and the corners aren't very sharp.
