Amp power and ground wire
tannerc
Well i will be receiving my amp next week and was wondering if anyone had some hints in running a stealthy power and ground cable to the rear of the truck?:biggrin2:
also recomendations for battery terminal connections :keyboard:
I run two fairly decent sized amps in the back and used 2 ga. battery cable . There is a spot on the drivers side by the steering column to pass it through ,then carefully under the carpet along the drivers side .All speaker wires and control cables run down the passenger side. I used a probe to make the hole so the wire , after install has a nice snug seal around the cable. I only ran the positive , the ground is terminated on one of the seat belt bolts on the rear seat. I went to an electrical supply place and bought a distribution block to feed both amps off one cable ( about a 1/3 of the cost as opposed to buying this at an stereo shop ). I have no noises , no hums , very clean sound . Oh for the power lead I just bought a terminator ring and took the nut off the battery power wire and slipped it on that way. Dont forget to get a good quality fuse and install near the battery ;)
