AMSOIL Engine & Transmission Oil on Discount!
AMSOILDealer
PM or Call for Specific Pricing
Current Promotion: 10% off your entire purchase (does not apply to S&H charges). This offer is only valid on full retail priced orders placed directly through Northwest Premium Lubricants. Simply send me the product(s) and quantity you'd like to purchase and I'll send you a quote.
Not sure what you need? Check-out our product lookup tool:
http://www.amsoil.com/guides.aspx?zo=1664628
If you're looking for one of our more specialized oils for your performance vehicle, the tool above will not list it, so send me the type of vehicle you have and what you use it for and I'll send you my recommendation.
AMSOIL doesn't just make great lubricants, but they also make additives such as the Performance Improver (P.I) which cleans your fuel system and can increase your fuel efficiency:
http://www.amsoil.com/lit/databulletins/g1135.pdf?zo=1664628
If you'd like to purchase AMSOIL products at wholesale simply add the 6 or 12 month membership to your shopping cart (http://www.amsoil.com/catalog.aspx?GroupID=228?zo=1664628) and then add the products you'd like to purchase. During check-out the prices will be adjusted to wholesale which is between 20-25% off retail.
To view the complete list of AMSOIL products I sell checkout the AMSOIL Product Catalog.
To see what products AMSOIL makes for your vehicle, check-out our product look-up tools, enter your vehicles year, make and model to get a complete list of products. This tool will not recommend any of our race oils; if race oils is what you're looking for send me a PM or call me at 541.914.1621 and I can send you a pricing.
I also sell the following products, Mother's Cleaning Products, WIX Filters, Donaldson Filters, MANN Filter, NGK Spark Plugs, TRICO Wiper Blades.
Here are a few firsts by AMSOIL :
• First to develop an API rated 100 percent synthetic motor oil
• First to introduce the concept of “extended drain intervals” with a recommended 25,000-mile/12-month drain interval
• First U.S. company to utilize the NOACK volatility test as a standard of performance excellence
• First to produce synthetic motor oils for diesel engines, racing engines, turbos and marine engines
• First to introduce synthetic oils that legitimately contribute to improving fuel efficiency
• First to manufacture synthetic gear lube for automotive use
• First to manufacture a 100:1 pre-mix synthetic 2-cycle oil
• First to manufacture a synthetic automatic transmission fluid for automotive use
To fill your order you can either hit up my website HERE, PM or call/text me at 541.914.1621.
If you don't live close to me, don't worry, we have distribution centers located in Portland (OR), Anchorage (AK), Las Vegas (NV), Orlando (FL), Chicago (IL), Wichita (KS), Columbus (OH), Lancaster (PA), Dallas (TX), Richmond (VA) and Superior (WI); your orders will either ship from the closest DC or you can pick-up from these locations as well if you wish. We also have two in Canada (Edmonton and Toronto).
Also, if you're looking to become an authorized AMSOIL dealer or have a business and would like to sell AMSOIL products I can set you up, so give me a call!
The NOACK Volatility Test determines the evaporation loss of lubricants in high-temperature service. The more motor oils vaporize, the thicker and heavier they become, contributing to poor circulation, reduced fuel economy, increased oil consumption and excessive wear and emissions. A maximum of 15 percent evaporation loss is allowable to meet the API SL and ILSAC GF-3 specifications. As shown in the graph, AMSOIL 5W-30 Synthetic Motor Oil lost an extremely low 4.9 percent of its original weight during high-temperature service, maintaining its superior protective and performance qualities,while Mobil 1 SuperSyn 5W-30 Motor Oil lost 9.17 percent of its original weight.
Bump for an Official Vendor
Thanks for supporting T4R.ORG so the rest of us can enjoy this great resource FREE of charge!!
:thumb3: :thumb3:
Sunday night bump and a little more AMSOIL comparison to Mobil 1:
The Four Ball Wear Test determines the wear protection properties of a lubricant by measuring the wear scars produced by four metal balls in sliding contact under the test parameters. The smaller the average wear scar, the better the wear protection provided by the lubricant. And the difference in real wear rates is a much larger percentage than the scar-size difference in this high-pressure test. That fact is well proven in countless millions of miles of fleet oil sample testing, where AMSOIL regularly delivers metal wear particle reductions of 40 to 98% in Iron, Copper, Aluminum, Chromium, Nickel and others, against baseline commercial fleet oils. As shown in the graph below, AMSOIL 5W-30 Synthetic Motor Oil completed the Four Ball Wear Test producing a smaller wear scar than the Mobil 1 SuperSyn 5W-30 Motor Oil.
Does amsoil ATF meet Toyota WS specs or is it simply recommended for applications that require WS approved fluid?....kinda like amsoil doesn't have a vw 505.02 or a Dexos1 approved product but claims the product is suitable for use where these approvals are required?.
The ATF is recommended for the following: TYPE T, T-III & T-IV automatic transmissions from Toyota. However, the ATL is not only recommended, but is engineered to exceed the requirements of WS:
AMSOIL - Synthetic Fuel Efficient Automatic Transmission Fluid (ATL)
'PRODUCT DESCRIPTION
AMSOIL Synthetic Fuel Efficient Automatic Transmission Fluid (ATL) is engineered to exceed the requirements of GM, Ford and Toyota where low-viscosity oil is required. The highly-specialized properties of this light-bodied fluid provide outstanding performance without compromising protection, even in severe operating conditions.'
my father makes regular trips out to the Lancaster location to stock up on oil both for ourselves and for friends and family that want it. It is the only oil we will use and once my 2 year free oil change cycle is over with Toyota I will be putting it in my new 4Runner as well. It's even coursing through the veins of my '91 Chevy Beretta with 150k that runs like its new.
