Annoying problems starting my 99 limited 4runner *Need Advice*
TRUST8383
Lately, I've been having problems starting up my 4runner. Once it's running, everything runs perfect...no problems whatsoever. But sometimes, when i go to turn the key, it'll just make a "click" noise, sounds like a relay or something, and nothing else will happen. So if i sit there for a second, try it again a few times, it will eventually crank and start. This is an intermittent problem, it'll be gone for a week, and then come back. If anyone has any suggestions as to what i should check/replace first, i'd appreciate it. TIA
It is either the starter or the battery. I suspect the battery. I would first try cleaning the positive and negative terminals real good and see if the problem continues. I would say that is the first and cheapest step to take.
It's not the battery, because i changed that out w/ a brand new one, and it still had the problem. Also, it's not a bunch of clicks when i turn the key...just one click, if that makes a difference. I guess in the back of my mind, i suspect the starter, but i was just checking to see if anyone had similar experiences.
Yeah but it still may be the connection. Unless you cleaned the terminals real good and tightened the nuts good there is still a possibility of the connection being the culprit. That is why I said to start there because even if you have a good battery a bad connection can still cause problems.
Toybox is right, though -- clean the battery terminals and connections first. I had a Mustang that did that, too -- was prepared to tear it apart and found out it was the battery connections.
Never hurts to start with the simple stuff.
Thanks guys for all the input. The battery terminals were clean.
I believe O2sport has my solution. Thank you so much for posting that link. All the symptoms you described are dead on. Sounds like a nice little saturday morning project, and then i can get back on the road with no worries.
Thanks guys, Jon.
Crookedcat
