Another Engine vibration question (1400-2100rpm)
cacarbuff
Another Engine/Transmission vibration question (1400-2100rpm)
So I've had this truck for about the last 32k mi (162k on it now), and just recently I have been feeling a type of slight shuddering or vibration when the engine is under load. 2005 v8 4wd
I know it's not a wheel balance issue or a driveshaft issue, because it seems to be rpm dependent and not speed dependent (it is worse above 30mph though).
There's a slight shudder/vibration in the steering wheel and a slight shudder in the gas pedal. It feels almost like the engine is lugging... It's definitely not the rumble strip issue as it's not a very aggressive shudder. My wife doesn't think that most people would notice it, but I notice, and it bugs me. A lot.
I've been searching for days, and the two most promising culprits I've found involve a really dirty air filter and MAF sensor (running a TRD drop in filter), and a cracked spark plug (cracked porcelain causing a grounding issue under load). I changed the plugs when I first got the truck and didn't start to feel the issue until very recently (maybe the last couple of months). Since I started to feel the issue, I've greased the driveshafts, rotated the tires, changed tire pressures, seafoamed the intake, and done a 12qt fluid exchange on the transmission.
I thought I would post this to see if anyone has any ideas before I start throwing money at it on Friday. Thanks for the help!
Vibration when accelerating
Mine just started doing this earlier this past week, I hammered it to pass someone that was driving slow in the fast lane and all of the sudden I have a vibration that comes and goes when I accelerate above 20 mph maybe even less.
My research has me pointed at checking the u-joints, mine have 197,000 miles on them and do go off road on a regular basis so not a bad place for myself to start regardless.
I will report back here after I either have them checked or replaced.
Can you feel it under drivers floor board ? Does make a rattle like noise at about 20- 22 mph & go away as you accelerate ?
BillM777
