Transmission Lag After Deceleration & Steering Freeplay
Wared
Hello Toyota experts,
I recently installed a salvaged OEM 1GR engine and A340F transmission in my 4th gen 4Runner. Both run well, but I’m experiencing two persistent issues:
1. Transmission Delay After Slowing Down:
The transmission shifts perfectly with no delay during normal driving. However, after slowing down, when I try to accelerate, most of the time the engine revs for about a second before the transmission engages. It feels like the transmission isn’t always recognizing that the car is slowing down and stays in a higher gear until I press the gas pedal, at which point it finally downshifts.
I suspected the throttle body or TPS might be causing a slow signal to the transmission, because they came from the old engine, so I replaced them, but this didn’t fix the issue.
2. Steering Wheel Freeplay:
I had this problem for years, there’s a noticeable 1–2 cm freeplay in the steering wheel. I can rotate the wheel slightly in either direction from any position by barely touching it with a pinky, and this movement has no effect on the wheels. I’ve checked or replaced most of the steering components, but the freeplay persists.
Has anyone experienced similar issues or can offer guidance on troubleshooting these problems?
Look up Toyota FlexLock torque converter system malfunction. I assume you are driving in "D" ?
Try driving in 4th with manual shift. My A750 tranny it is S4. Manual shift changes the Flexlock shift timing to lock and unlock. Maybe you can get a clue?
Also what ATF brand is in tranny?
#1 no idea
#2 There's a u-joint near where the steering shaft connects to the steering box. The joint dries up over time, gets water in it and wears out. Usually the hoint will feel really notchy before it fails. Not easy to swap but there are worse things. Link to one below.
Also, some have mentioned the rack bushings going bad but you would see the whole rack move if that's the case.
Amazon.com
If you want to keep your car for a long time — don't skip an early check-up. Transmission lag or jerking when decelerating + "free-play" steering could be a sign of a serious gearbox problem.
Edit by survival race a day ago
wwarren702
