another fiberglass 4runner ...
slacker
another fiberglass 4runner ... DONE !
rolled into the shop today ...
/89 "special edition" 4Runner .. for a Major body and paint refurbish ..
HPIM0992.jpg~original
HPIM0993.jpg~original
HPIM0994.jpg~original
HPIM0995.jpg~original
HPIM0996.jpg~original
HPIM0997.jpg~original
Gotta love that thin sheet metal.
If you're going to buy a 4Runner, check out any one from central / west Texas, Arizona, or Southern New Mexico. No snow means no salt, which means a longer life for the body panels.
also started pulling the "cosmetics" off the front ..
HPIM1009.jpg~original
HPIM1010.jpg~original
removed the running boards ..
HPIM1011.jpg~original
and fenders
HPIM1012.jpg~original
HPIM1013.jpg~original
hard top front windows( L trim windows)
HPIM1014.jpg~original
and finally the hard top ..
HPIM1018.jpg~original
HPIM1017.jpg~original
damn....I though Hawaii had choke rust....you should just turn that thing into a rock crawler already....
Good luck bro...keep us updated with pix
surface rust on heavy suspension pieces , is acceptable ..
but heres an inside view of the "stock" panels .. with some previous repairs .. some of you guys think ..welding in new steel works !!
HPIM1022.jpg~original
HPIM1023.jpg~original
WASTE OF MONEY .. like I have been tellin' you guys for years ...
so got the rears cut off ..
HPIM1032.jpg~original
HPIM1033.jpg~original
and started on the gate skin ..
HPIM1034.jpg~original
HPIM1035.jpg~original
did some POR 15 work on the truck as well as the gate ...
HPIM1041.jpg~original
HPIM1042.jpg~original
and "glued"
HPIM1047.jpg~original
mountainman_gz said:
Nice work!
How much would an over haul like this cost?
this one .. by the time all is said and done .. including new paint and windshield (as I will keep you posted ) is going to come in @ ~ 8G .
8g's...i hope you are not shorting yourself...all that labor is worth at least 10k...but I will keep that to the professionals.
Good luck, cant wait to see the next round of "engineering".
your absolutly correct ....
but because it's a 4Runner .. i'm kind .
ok .. so today fit the fronts ..
HPIM1036.jpg~original
HPIM1037.jpg~original
HPIM1040.jpg~original
and trimmed the door edges ..
HPIM1039.jpg~original
and fit the rears .. and gate .
HPIM1050.jpg~original
HPIM1048.jpg~original
HPIM1051.jpg~original
HPIM1049.jpg~original
HPIM1052.jpg~original
HPIM1053.jpg~original
glue tomorrow ... :)
so what does PO15 do?
whose ride is this? friend, family, customer?
what is the end result of this rebuild? stock look, beast, crawler, showcar...etc?
Are you touching the engine, suspension, tires? Or just body?
it's a customers truck , and it's a stock 4runner , and basically staying stock . he uses it for mostly winter driving , but hes also a mountian bike rider , and climber .
powertrain is in great shape , and motor runs like a champ .
por-15 .. in lamans terms .. paints over the rust , and stops it from breathing .
so now with all the panels fitted .. time to make PERMINENT
HPIM1058.jpg~original
HPIM1066.jpg~original
and while curing ..
and with the inners painted , I was able to seam seal the new parts ..
HPIM1065.jpg~original
hood weatherstrip , and clips installed
HPIM1067.jpg~original
and hood installed and aligned
HPIM1068.jpg~original
door installed , and aligned
HPIM1069.jpg~original
Slacker, that is the coolest set of "how-to" photos I have ever seen. Like Hayn4R, I was wondering what the purpose of it was.<br>
Another question, how many miles? I have an 89 that I consider at the end of its life, 248K, with quite a bit of body decay.<br>
What about the rust on the leaf springs, underchassis? And did you make the quarter panels?
