Another High Idle 3.0 thread
Ahlem
In working through the new to us 1993 3.0 automatic, the latest issue seems to be a high idle and erratic hunting after coming off the freeway occasionally. There was a fair amount of effort put into cleaning out the fuel system but not the TB or idle air control or MAF/AFM(?) just yet.
The idle stop screw on the lower side of the TB has a paint dot on it that looks original and other than it appears to be a PITA to loosen and adjust the lock nut and stop screw, I think it's probably something else causing the issue.
I haven't checked the timing yet either. Any suggestions? I plan on starting with Carb cleaner at the TB first.
Here's an update.
I made this after a visit to the local LKQ. The crimp on butt connectors are crimped just enough on the open end to hold my multi meter probes nicely.
I adjusted the TPS properly. I was having trouble keeping the probes in good contact in the very cold weather here. I then broke out my 1973 vintage timing light and "discovered" someone had set the timing at 18 degrees or more BTDC. After I put it at the specified 10 degrees, it runs way better and closer to reality. It will get a couple days of test driving to see if it needs further help.
Did adjusting the TPS cure the high idle? Mine does the same thing and adjusting that is one of the many things on the to-do list
Between adjusting the TPS and setting the timing, major improvement occurred. It's still surging after coming off the expressway when I shift to Park when I get to work. I need to check the fuel pressure due to possible clogged fuel filter issues. See my previous thread on what we found and running on 3 cylinders.
I may have a rusty gas tank but haven't been too anxious to drop the tank with the sub zero weather we've been having for a good part of January and February. I also discovered a nice sticker under the hood that has the EGR hose routings so I can double check to see that I didn't get something reversed when I had the intake plenum off.
Another update...
The surging idle is now gone I think the TPS adjustment and timing adjustment took care of that problem. Last week when it was 50 degrees F outside, the car idled too low and I had to adjust it upwards to get to 800rpm. We had a big temperature swing and it was back to 1200 rpm at 25 degrees F. I'm leaning toward a temperature sensor issue. How many temperature related sensors are there on a 3.0 and where are they located? I'm thinking there is a coolant temperature sensor, an idle air control sensor and possibly a temp sensor in the AFM area some where?
Yes, there is an IAT in the MAF sensor, see the pinkish-colored wires in here?
That goes to the IAT. I don't recall if there's another one somewhere else, just drawing a blank right now for some reason! Guess I have too many other things going on in the shop today...:lalala:
