another noise, and wheel problem
7echo
Member
I hear an occasional clunk. Seems like it is coming from the back of the truck. Crawling under I can't find it yet.
I can grab the top of the tire and pull and push it back and forth and it shakes a little. And I hear a clunk.
What do you guys think? Any tests I can do?
About 110,000 miles currently.
I just solved my clunk in the rear and it was a worn track bar (bushings). I pulled a better looking one out of the junk yard and it solved my problem. I was pretty sure that's where the clunk was because I could grab the bar and push and pull it about a 1/16th of an inch, you shouldn't be able to move it all.
check it out
I will check the track bars.
I am concerned that being able to pull on the top of the tire and it seems loose is a rear end issue. Or bearings.
Other ideas are appreciated!
