Another reset needed?
t65k3
I got a 03 SR5 V8, 198k. Seat leather cover was torn so I was working on it for two days while the battery was disconnected. Upon completion, I reconnected the battery and it started up right away. BUT I didn't realize the reset procedure I was supposed to do. (i.e. idle for 15min.....)
On the way to a store, engine stalled at the red light. The RPM would drop so low and the engine would just shut off. It happened whenever I let go of the gas, including making turns, stop at signs.... But I could start it right back up followed by giving it some gas
Symptoms:
1. Could not maintain normal idle rpm ~600. When I was not giving it gas, engine died.
2. Lost power steering while RPM showing 0, and car was still moving, gear in D.
3. Later, when gear was in park, RPM would fructurate, pop from 500 to 600 whenever a clicking sound came under the hood. It clicked once every second. (Maybe AC?)
4. Reduced power at higher speed, heard clicking sound (different from #3 above) when hitting 65mph during acceleration.
I picked up the SUV trying to drive home at night. About 15miles later, the problem disappeared, at least for now.
Did it learn my habits already?
Should I get the alternator checked out?
Do I need to disconnect the battery and reset it again to be sure? I have a road trip coming up in a week so any advises are appreciated.
Thanks in advance.
Wow, having same problem! N just had alt replaced yesterday in attempt to fix problem. 03 V6 249K
Sent from my SM-G973U using Tapatalk
i disconnected my battery for hatch motor replacement. i reconnected and started it right up, no issues. had to play with door locks and auto windows but nothing other than that...
All I did when I had my battery disconnected for a week or so was let it idle in park. It eventually sorted itself with no stalling but the rpm's did go up and down before it stabilized.
Wow, I never knew about the 15 minute idle thing. Glad I read this. Guess I got lucky when I changed the battery last time. All I needed to do was reset the windows and stuff, but the truck seemed to drive fine without re-learning.
& how do you reset the windows & stuff?
Status update:
I picked up the car at night and drove at a steady speed of 40mph taking advantage of quiet streets. 15-18 miles later, engine started to run fine.
Till today, no error code. Seems ok now.
I also have the V8 and am having the exact same problem after disconnecting the battery to remove the center console to adjust the parking brake. It dies whenever idling. Have driven 22 miles since disconnecting battery and it still won't idle.
Can anyone confirm there is some reset that has to be done? I have disconnected the battery many times before and never had this problem in 275k miles of driving it.
One more thing, after a short test drive for the parking brake adjustment I cycled the 4Hi/Lo and CDL without any issues but maybe this messed up the ECU reset?
I parked the car at a nearby parking lot after engine went out like a dozen times. I picked up the car in the middle of night and drove about 15 miles at a steady speed of 30-40mph, trying not to have to stop at lights or left turns. And it was good since.
If I were you, I probably will try to disconnect the battery one more time for more than a few hours to make sure the memory is cleared. And then reset it properly by starting it up and idling for 30min or so.... That's what id try.
Good luck my fellow V8 T4R
I disconnected the battery again to do a reset and it idles fine now. At first after warming up it died but then gradually idle speed increased as it did the relearn.
AndiGarage
