I decided to install short tube headers on my VVT-I V8 with 200k miles. I bought new OEM manifolds from Toyota during a 25% off sale for about $700. I wanted new cats just given the amount of effort these take. My old cats were still ok. I also replaced the motor mounts at the time since you have to lift the engine a bit anyway. Can definitely feel how bad my old ones were after replacing them. Less vibration when it’s running and when it starts. I paid a mechanic for 17.5hrs of labor. 3 of that was fabrication. After it was all done he said he wouldn’t do the job again. It’s definitely not fun. The access to the studs on the short tube headers is about .001” away from impossible. You have to even cut down an open end wrench to have any chance to tighten one. Forget about using a torque wrench. I kept the factory y-pipe since my exhaust is still in good condition. New Denso upstream O2 sensors as well. We cut down new Toyita metal gaskets to fit vs using the Thorkey gaskets. New Toyota studs and nuts as well. All studs came out with no issues.
I will say mid band power is better. City gas mileage did not change really. Probably too much idling, acceleration and low rpm’s. Highway mpg went up about 1mpg. My 4Runner is basically all stock other than the headers. I feel like the 2-3mpg claims on the internet are overstated and I’m definitely not a lead foot. I did see 2-3mpg gains for the first 2 days but I think that had more to do with the ECU reset since the battery was disconnected for 3 days. It eventually settled out at same for city and plus one for highway after a couple fill-ups.
RRcats offered me $230 for my old cats.
