another suspension question with a twist.
alrighty! got my suspension in tonight and did it within 2 hours.
actually not to bad ran into a couple push backs but nothing major that couldnt be fixed easily.
i dont have pics because it started to turn night, well i started at 8pm ended at 10pm haha
basic tools floor jack, jack stands sockets, and such.
so problems that "very small problems that set me back"
panhard rod doesnt line up nicely at all after you take it off, had to pry it with a driver to line up the hole and hammer the bolt back in.
shocks are blown and old and never changed since i bought the car so i got the bottom bolt off but it was impossible to take off the shock i dont know why but i figure cause its age so i left it.
springs i had to pry out kinda spooky cause you think it will hit you but not to bad, was working with 2 other friends so was all good.
they came out and i didnt have anything that looked like the writeups on here my spring is empty with no rubber stops inside.
so i wired up the airbag easy with the given rubber boot thing that easily wired it straight up and over the springs. in a way i like made things much much easier, no drilling what so ever.
so that took about 10 seconds to put in the spring then had to pry the spring back in with NO spring compressors all elbow grease some smart thinking and 2 friends haha
then that was it all finished.
the ride was MUCH MUCH improved, some say oh the ride gets stiff but not for me i like it wayyy better. then again maybe it was beacuse i was used to driving it bottomed out and blown shocks with compressed springs HAHA
but hieght it back to normal, actually higher then normal. but ill leave it at 33psi for now and check tomorrow to see if it went down to see if i got leaks. then ill level it out.
but damm i love it i can finally drive relaxed and not worry about bumps and bottoming out all the time.
now ill NEVER bottom out and my truck doesnt have the sag.
i say +1 for the airlift.
with the t line hose adapter its very easy to fill both bags at the same time at equal pressure levels.
ill get pics asap thanks everyone
yupp cherry amps. very underrated!
thanks i havent got pics of the airbags yet and i didnt take any during build and right now im to lazy to walk outside and take pictures haha
SOON i will promise haha
Glad to hear the AirLift helped! Have you had a termlab in there yet? Also it's good to know Irraggi makes a HO Alt for the 4Runner, If/When mine fails I will definitely upgrade to one of those...
One more thing, I'm curious as to why you are running a Red Top under the hood Vs. a D34/D37F Yellow Top or another Kinetik?
good question i get asked sometimes, well the way i see if i have enough battery bank for my amps and such in the rear that the red top is more just there as a starting battery. its a strong starting battery and although not as deep cycle as the yellowtop my voltage will never drop low enough to use the function and i wont kill it cause its constantly being charged and topped off. so it serves more a purpose of a starting battery and also another small reason is another kinetik to get in there would only fit a 1800 or a 2000 at the most and money wise i dont "need it" and ive had the red top before all this equipment so it stays for now haha
i got pics nowjust gotta upload :D
pics are promised. :D
the night we got it in, i saw an instant lift; LOVIN IT!
IMG_0800.jpg~original
it might just look normal, but to me with all that wieght back there and it still looks normal is a PLUS to me! :D
IMG_0801-1.jpg~original
just another pic
IMG_0802.jpg~original
bags
IMG_0803.jpg~original
its been t lines so i can fill up both bags together and have equal pressure and i routed the lines here to the end of the frame for hidden but easy access for me
IMG_0804.jpg~original
i know air lines are a little messy but it was just to test it all works id hate to make it all nice the first time and have to dissasemble but its all good so now its time to clean it up :D
so far i love it, rides good, dont have to worry about botteming out. and i can enjoy still having all my sounds without having to worry about every bump i hit :D
thanks guys
stc6306
