Anyone Fit Brand new BF Goodrich All Terrain tires, 31x10.5x15 Stock???
4RUNONU
<===== NEWBIE:ybrick:
Hey guys: just wondering if i got
American Racing Baja Wheels, 15x8 with 5x114.3 bolt pattern without a lift is it possible???
The bolt pattern is wrong. You need a 6x5.5. The tires will fit just fine, but you might want to look into getting 16's. Better selection of tire sizes and you can do the Tundra Brake Upgrade.
What kind of 4Runner do you have? Year, model, etc etc. That will tell us if you can fit the tires. Some 4Runners came with larger front brakes, so you need at least a 16" wheel/tire combo to clear them. The wheels you listed won't work either way since they are a 5 lug pattern and Toyota's are a 6 lug pattern. The size of the 31's should fit fine with no lift.
I got a 2001 sr5, right now im running on the tundra rims, with 265 75 16 BFG AT/KO and the right is going bald and im in the process of getting tires but.. :dammit: im picking on if i should just get both rims and tires. so im in the market but in need of tires(priority)
Best to get another set of tires for those rims. The 16's are a far better choice anyway.
Well, if it's not a sport or a limited, you should be able to run 15" wheels, but I also agree that there are (in my opinion) better options with 16" wheels. Plus what COB said, it will allow you to upgrade your brakes down the line if you choose to.
Why only some SR5's had small brakes, if it came with 16's stock then 16's are smallest you can run.
