Anyone had this problem with their AC?
RevoRunner
I have an 04 Limited V8 with dual air control. With the AC at full blast the passenger side blows in the 40-50degree range while the driver side blows just over 60degrees. I'm guessing there's a problems with dual air climate control but don't really know the system or where to start.
Anyone else have this problem? Just wanted to get some feedback before I left my fate to the squeeler.
Have you checked to see if the cabin temp sensor is plugged in? It's the small vents that's located in the lower dash panel under the ignition key and above the gas pedal.
Check your freon level, mine is doing the same, not a dual zone system, looks like I have a leak in the evaporator cause the dye is showing up in the water drain drip area.
