Anyone in SD/OC that can help with rear axle seals?
APhelps
Currently my 98 T4R is leaking a little bit of gear oil into the ABS area and I'd like to fix this before it gets too bad. If someone has the garage space/press I'll gladly work out an agreement cash wise for the job. Probably could barter as well (you have garage space and I'll buy a harbor freight press for you to keep) or such.
Shoot me a PM if you can help and we can work something out.
Should have the tool to press the axle bearings, retainers and abs gear on and off soon. Probably going to do the work next friday on base (they have a press) but I'd be willing to lend a hand to someone else if they end up needing it.
That's a tough one. Pull the axles and take them to James at the truck shop. have him press it in. At least you will know it is done right.
I should be able to do the job Friday without much concern. There’s a press at the hobby shop which will get the job done. I don’t have much interest in having to do a grease test only to find out the work wasn’t pressed enough or too much.
