Anyone Interested In a 3 inch OME lift kit 4th gen's
aha2988
I have a complete lift kit from OME the front is the 886 setup and the rear is the 897 setup. This kit fits all 2003-2009 4runners
I'm looking for anyone interested before I post the sale for them in the classified adds as I will need to purchase and install new front adjustable coil overs before having the complete kit ready to sell
there's only about 20,000 miles on the springs and shocks, rear shocks only saw about 6,000 miles before they were swapped out for an extended travel setup.
I wouldn't be looking for much money for the kit. Mainly just interested in moving it to someone that could use a lift and doesn't have the budget to purchase a new setup.
The fronts will come with the OEM top hats already installed so all that will need to be done is bolt everything in. no spring compression necessary.
This is the Old Man Emu setup designed for the weight of the V8 setup along with bumpers, winches, dual battery. will work for the V6 as well just allows you more weight addition ability to the front end.
basically the front is rated for and extra 200 pounds on the truck in addition to the weight of the V8 setup, and the rear is rated for an extra 400 pounds of continuously sprung weight.
With the kit installed all alignment specs are capable of being set back to factory except the caster angle. An aftermarket UCA will be required to gain factory castor back with the setup
PM me if you are interested or post up any questions if you have them
again I plan to sell them once I replace my front coil overs which won't be to long. mainly just curious if anyone here will be interested.
cool, I'll get my front adjustable coil overs on the way and post up when the kit is ready to sell.
2001ATL
