I searched but nothing came up. Curious if anyone in the collective has a Kamook Crosswing awning. If so please share your experience.
:lookout:
I see that review, but I find it hard to believe. After digging further it seems even those that bought the kickstart won't get them until November.
True. Maybe early production prototype? Regardless, I dont think I could spend $1k on any awning. TBH my privacy tent gets used more than my 8'ft awning
Oh dang, I read 600 bucks I didn’t know what it was more like 1000. Ain’t no way.
I think the main attraction with this awning is deploying it in about 30 seconds or less. Do you guys that don't use your awning much think you would use it more if it was that easy to set up and take down?
If it's a real windy day then maybe its a gamble to deploy any awning, it seems to me like the vertical poles do nothing, unless they are staked down.
The test videos that show the guy throwing logs on top look impressive, but I wish they would have taken it all the way to failure. Overall it does SEEM pretty solid.
The other plus, for me anyway is it mounts directly to factory cross bars, so no need for a heavy roof rack I don't want or need. I would need to put my factory rails back on, probably try to find some black ones though..
I do like the OVS Nomadic 180, the 270's are out for me due to hatch interference. Thanks for all the input.
What privacy tent are you using? I've been eyeballing those so I don't have to do the towel thing when changing after a sweaty MTB ride.
Just a heads up on the OVS 180, it interferes with the hatch as well. If you stand behind your rig with the hatch open and line up the side of your rack you'll see that the back pole will hit the hatch. The 270 may actually interfere with the hatch less than the 180. I had one and after a lot of playing around I realized the only way to mount it is very high so it wouldn't interfere with the hatch which I didn't want to do. On top of that the supplied mounting brackets were awful. They would either need to be gusseted or replaced with something more stout. Mine bent so much it cracked the powder coat off. As well the droop of the awning under it's dry weight was crazy, it really couldn't be used without it's poles. So ultimately I sold it.
My experience/challenges with awnings is two fold. Wind and rain(or snow). I don't think there's any awning that wouldn't ultimately have a problem if there's enough wind and need to be staked down. And staking without poles doesn't work well. Then rain, your standard rectangular awning doesn't shed water almost at all, it pools in the center. If you use a spreader pole you can improve the rain running off but that's an additional purchase. Then if you combine both wind and rain which usually come together.... Fast pitch is a cool idea but at some point your probably gonna need the poles so I wouldn't get one that didn't have them at least as an auxiliary.
I have been looking at the OVS 180/270 for a while but wasn't sure if its durability or how much actual use I would get out of it if situational. I use a smittybilt XL with the annex and its been great in wind, rain, snow etc.
Do you currently use any awning at all and find it useful? or is it just more trouble than it's worth and can only be used in ideal weather?
Regarding the OVS, I think the general build quality was ok, a bit on the light weight side maybe. My issues were the brackets sagging and the hatch contacting the awning bar.
If I was going to get a 270 I'd seriously consider a Quick Pitch awning
Quick Pitch Weathershade 20 Sec Awning '-' Quick Pitch USA
I have had an ARB 2500 for about 5 years and it's worked really well. I have the side wall set also. (Room with no floor, not made anymore) It would be nice if it was bigger. I added a spreader bar which helps it shed rain and snow much better and if you tilt the front of the awning strategically you can get the water to shed a bit better
CURVED 2/2.5M AWNING SPREADER POLE - Drifta Camping & 4WD
On that same site, Drifta, they have some good looking awnings (and other gear too). However, getting their stuff here from Australia is challenging and exspensive. If you decide you want to deal with them I can give you a few tips, however, it'll be a wait no matter what
Thanks for that info. The quickpitch awning looks nice but is also 2x the price of the OVS. Does the ARB awning actually provide significant cover during rain/snow and from sun? or only if the weather is coming from directly above with no wind?
