AOB switch question... is a relay re
GearJunkie88
I’m hoping someone can educate me on the use of an Air Onboard switch to control a small LED strip. I have an AOB switch like this: https://www.aironboard.com/online/p...-oem-replacement-flux-capacitor-led-blue.html. The website says it is “rated at 12v 3 amps. Therefore in ALL cases the accessory MUST be wired through a fused relay.”
I want to control some footwell LEDs like this: https://www.amazon.com/dp/B074CHFN1...olid=1ESL5PX6P6SV3&psc=0&ref_=lv_ov_lig_dp_it. They are 12v 0.25 amps.
I’d like to run hot from drivers fuse box #2 (instrument panel lights, 7.5 amps) using an add-a-circuit (https://www.amazon.com/gp/product/B01BU59OL4/ref=oh_aui_search_detailpage?ie=UTF8&psc=1) to the AOB switch to the LED strip to ground (screw next to the drivers fuse box) - without the relay… Do I really need the relay? It seems that since the LED strip amp draw is so incredibly low I don’t need the relay… but I’m no electrician.
Thanks for the help!
"...Do I really need the relay? It seems that since the LED strip amp draw is so incredibly low I don’t need the relay… but I’m no electrician.
Hi GearJunkie88,
Based on the system specs sheet, you 'DO NOT' need to use an additional relay, "See below":
Specification:
Voltage:12V
Power:6W
Current:0.25A
All you need to do is remove the product's switch from the harness and connect the three wires to the AOB switch's wires on the new (snap-in) switch harness!
Wiring is as follows:
Green is 'HOT' to feed the switch from the cigarette lighter. Red is the Trigger circuit, which energizes the supplied relay in-harness. Black is a ground to the AOB switch for the ON/OFF indicator light.
Blue is an option; this is fed by the instrument cluster/parking light circuit so the AOB switch will light-up with the other dash switches when the parking/headlights are on... you don't have to connect that feature if you choose not to! Hope this helps, 'Best to you',
rig
[MENTION=83083]rigtec[/MENTION] - Thank you so much! I thought I could do this without the relay but I didn't want to blow up my runner!
