ARB 2500 x 2100 Awning Room with Floor - N. California
209ers
2500 x 2100 Awning Room with Floor - ARB - DA6832 / ARB4412
Designed to function as a fully enclosed room, the awning with floor provides additional weather protection and privacy. The awning room can be used with ARB awnings and features a durable floor, two large mesh windows with roll up blinds and a zippered door with both solid and mesh panels. It is fully enclosed with an integrated roof that hangs just below the main awning canvas. Rear wall features a central door that can be used to directly access the vehicle rear door or canopy depending on awning mounting position. Access points for 12v/240v power leads. Supplied with hardened steel pegs and adjustable tension straps.
I believe this will fit the older ARB awnings, not the new ones w/ the LED strips but I'm not 100% sure because I have the older ARB awning only.
This requires the ARB 2500 awning (not included)
This was only used once, literally the first time I opened it I found out that my awning was the ARB 2000 and had t ordered the wrong part, however it was non-refundable. I can’t get it back in the box, but it comes as you see here with all the parts complete.
200 OBO
Located in Northern California (SF, Stockton, Manteca, Modesto, Sacramento)
