ARB on-board compressor which one?
TrDpRo_J
Hi all,
So i've searched and watched several videos on youtube and I'm trying to decide which on board ARB compressor to get.
I off-road when I can and MTB ride alot so it will get used every other day min and also plan to do one out of state getaway adventure a month with the fam.
Has anyone bought the single cylinder compressor and felt the need to step up to the double version because it just wasn't adequate?
Appreciate your input
Hi all,
I have the single. Does the job. If I wanted speed, Id go CO2.
I had the double in my jeep. It was awesome and necessary for 35s. COs is faster but a total PITA to constantly keep filled.
I would totally buy the ARB double again but I wont mount it in the Runner. It was kind of a pain to mount in the jeep (cleanly) and then after all that work I let it go with the jeep.
My T4R will never have tires bigger than 285s so I am thinking the single might work as long as I can run C rated tires. E rated need more psi so going from 12 - 45 with a single four times might take a very long time.
Buy the double, keep it mobile and you will have it forever and never regret it. That is what I will probably do.
Single works perfect for me. I haven’t used it since fall but I believe it only took about 6-8 minutes to air up. I have load rating E.
I also have the single. I MTB at least 2 times a week and have had to use it when the fiancé had a hole in her rim. (the stans tape finally failed) I was glad I didn't burn up those little co2's and could use the compressor. Like one has said, co2 was nice and fast, and it did help me seat a tire when I had to replace a valve stem, but I could have done that after I got home. From what you have indicated, I would suggest going with a single, but that's just me.
Side note: Regardless of whatever unit you purchase, take an old advil bottle and put the attachments in it, such as the needle for a ball, the air mattress attachments, and a presta valve adapter.
Enjoy
AndiGarage
