ARRGGHH!!! more than I bargained for.
2k54RUNNIN
ARRGGHH!!! more than I bargained for. update with pics
Projects always never seem to fail to surprise you and always more than what you bargained for.
Well I thought that I would put my Cornfed 3/2 spacer lift on this past weekend. From what I've seen and from the instructions, I felt I shouldn't have to spend more than an afternoon putting them in and then go to the tire shop, where my tires have already arrived. I went over to a buddies house, he has more tools and I could use the help. Everything was PITA from the get go. Every bolt, nut, and or screw that can seize was seized. So many cans of PB blaster and elbow grease we were able to get the shocks off without breaking anything. Took longer than expected. Since we have the wheels off, I decided to look at my brake pads, well they were worn and almost done. Since I am at it, I might as well do the pads. Finally got the spacers installed in the front suspensions, time to do the brakes and then put the wheels back on and start on the rear. Of course every pin and bolt were seized, but nonetheless marched on and got the brakes done on the passenger side. The driver side, there was a problem waiting for me. Turns out, one of the pistons in the caliper is seized and I can't put in the new pads. But also something I have to fix quickly as I don't like to things like that linger. Since my truck is still under warranty, I am trying to see if the dealership can take care of caliper this week.
With the front lift done, time to tackle the rear. We figure the rear would be quicker, since there was less bolts to remove and it just drops in. Only problem was the driver side rear shock wouldn't budge and can't get off the axle mount. We tried everything to remove it, short of destroying it. It was already late into Saturday night trying to get this shock off the shock mount. So we gave up, and I carefully drove home with the rear driver side not lifted, and will tackle the job again the next day. Sunday morning, we got another buddy to open up his shop to help us remove the shock. We had to resort to torching the dang thing off, and of course burnt the bushing. Finally replace the bushing and able to put the lift in and now the whole truck is lifted and ready for the tires, which I am going to go and put on today after work.
But of course I have another surprise waiting for me. Both the rear axle seals are leaking. There is grease all over the rear hubs. :redbrick: Of course I just can't let this be, or else I am just asking for it down the road right. So I will have to spend more money to get this taken care of this week.
After a knuckle busting and frustrating weekend and having to spend more money. I now have a lifted truck that will get its new tires today. I will post pictures later tonight after I go get the tires mounted and get home. AAARRGGGHHHH!!!! Just needed to vent a little.
I've been there. It's all worth it in the end when you look at that newly lifted truck though. Right?
if it makes you feel any better, it's always 1 step forward, 2 steps back when modifying a vehicle, no matter how much you spend, or how many fancy tools you have, I hate people that say they didn't have any issues when working on a vehicle, no matter how much I prep or plan, there is always something.
Yes I totally agreed with both of you. I have many other projects, that are just sitting in the driveway because of setbacks. Of course after all the hard work and frustration, it is all worth it. The satisfaction of the end product and that you did it yourself.
Hey, same story here man. Planned to do a spacer swap/spring install by myself in half a day, which ended up taking all day due to siezed nuts and general PITA moments. By the end of it I could barely lift my arms. Noticed that the RR axle seal is leaking and the RR brake is contaminated. Then noticed the RF diff side seal is leaking. Then, during the test drive, noticed the LF caliper is dragging. Sigh. At least we're working on Toyota 4Runners and not some inferior brand!
I am not handy enough to try something like a spacer lift by myself. I had my mechanic install my Cornfed 3/2 lift and he swears that he will never do another one. He worked on it for four days between other jobs and said it was a major PITA. I also added Spidertrax 1.25" spacers and the net result looks awesome. I feel for you guys who went the DIY route. It is amazing when people write how easy it was.
A couple pics...
IMG_0121.jpg~original
move to Arizona or move the snow out of Minnesota.
took myself about 3 hours to swap out all 4 corners from stock to FJ coil and shocks on my wife's 04. it already had 123k miles on it then. it was rust free from Kentucky.
It truly is the winter driving that is the killer to the undercarriage. The chassis pictures that some of you southern guys post make me dream about simply rolling underneath and undoing a few bolts without having Loosen All, cheater bars, a hammer, and a cutting torch waiting nearby.
Well as promised, here are the pics of the truck. Had to wait a little for the tires. The tires should have been here on Friday, but when I got there they didn't have it. The guy demanded that his supplier put it on a courier and get it here, since it was the suppliers fault that they weren't deliver on time.
3/2 Cornfed spacer lift with 275/70/17 BFG AT KOs. Fits in spare location with plenty of room. And I have a hitch too, I think it is the hidden one. No rubbing anywhere so far. But if I put in wheel spacers, I'll have to trim. But for now no trimming.
Before
064Runner47V8SE1-1.jpg~original
After
lifted4runner01.jpg~original
gap that I have in the back, might need to remove the mud flaps.
lifted4runner03.jpg~original
A couple pics...
[/QUOTE]
what size tires are your running there with that 3/2? looks good!
