So I installed a Gentex 177 mirror today and I can't seem to get it working. Here's the details:
I purchased it on eBay, it is used, and cosmetically looks great. It included the 7 pin connector and wiring harness. There were 2 wires, red which I was told was power, and black which I was told was ground.
I followed the wiring and install instructions from the Toyota PDF in this thread (http://www.toyota-4runner.org/accessories/715-adding-auto-dimming-rear-view-mirror.html#post7114). I wired it to A9 per the instructions. The only area I deviated was in the grounding; instead of wiring to a ring under the grounding screw, i T-tapped a ground wire in the bundle below the screw.
I ran 20g solid wire from the mirror to the power source.
I know it's not connected backwards because I already tried flipping the connections and it still didn't work. The compass is blank and shining a light on the sensor does not appear to make the mirror dim.
So my questions are these:
1. Is there a secret to waking this thing up? It should turn on automatically, or at least the ones I've had in past vehicles have.
2. Grounding it where I did shouldn't have made a difference, right? It's tapped to a wire that is connected to the grounding screw, so it should still be grounded.
3. Do I need to run a heavier wire? The wire on the pigtail looked the same size when I compared it to the 20g.
I contacted the seller with much the same information, but thought I'd give here a shot too.
Thanks in advance!
-Patrick
Thanks in advance!
-Patrick
