Automatic gear shifter movement
brianch
2001 Toyota 4 runner 110,000 miles, 2wd, automatic, as you drive down the road and have your hand resting on the shifter you can feel it move back and forth as you go over bumps and slight dips, not enough to come out of gear but enough to seem weird. Possible transmission/engine mounts worn/loose ? any ideas ?
sounds normal
from what I have read on some other post this seems pretty norm due to the age of the vhicle I will probably still put fresh mounts on just to see if it helps
freddygino
