I'm working on installing additional backup lights on my '03 SR5 (thanks for the inspiration, Lowpro!) and have a couple of questions to bounce off the group:
1) I need to run wiring to the back deck, since I want to place the relay close to the reverse light and tap into that for the trigger. What's the best way to do that? Can it be done without removing too much trim (those big plastic panels never seem to go back on as tightly as they were originally).
2) I followed Lowpro's links to the F150 forums and found a link to this page, which is really what I'd like to do - gives me the flexibility of using the lights as both auto and manual, but prevents any legal and safety issues if I put the car in drive and forget to turn off the aux. lights in the back, something I'm quite likely to do. I think I worked out the wiring sequence, based on this diagram, but I'm not an electrical expert, so I'd like some confirmation that I've mapped out the relay connections correctly:
The original install keyed the logic relay off the ignition wire, so if the ignition was on, but the car wasn't in reverse, it wouldn't work, but I think it might be more practical to key off the "Drive" position, that way I could use the aux lights with the engine running, but not if the car is in "D", so I couldn't have them on driving down the road.
Logically, when the ignition is on, the N/C switch, 87a would open, and the N/O switch, 87 would close, so that the power relay will receive signal from the fuse block if the ignition is off, but the reverse light only if the ignition is on.
Thoughts/Suggestions?
