Baby Seat in a 99'
Snookster
So i went to install the Graco car seat base in the runner. Because Lilly (my 9 week old daughter) wanted to take her first ride. I couldn't figure out how to connect the base. It is different from my old 2001. Does anyone have experience with this?
You just put the base in the center of the rear seats and secure with the lap belt. There are no lower anchor LATCH type connections built in.
Take it to your local police department. My brother, when a patrolman, used to show people who came by how to properly install their child seats all the time. He said he was shocked how many people didn't have their child seats installed properly. Take it by there and they will have you hooked up properly in no time. They will also show you the proper way your child should be restrained in the seat itself. This is one concern I would not hesistate to get a professional opinion on.
p nut said:
^ What he said.
Side note: When I have a kid, THIS will be the seat of choice for me. :D
one problem with that, my daughter is 9 weeks old.
I tried to go by 2 fire depts. and they said I have to make an appt
YEP, make an appt at your local FD (or maybe PD). They put them in for my wife' car because it made her feel better about it. But I put them in mine. It could not be simply. But like I said if it makes you feel better go to the FD/PD.
Snook -
Congratulations!
I have a '99 and have had a lot of practice with installing car seats (had 3 to date).
For the 4Runner (and IMO) all vehicles the best place to install the seat is in the center of the back seat. Many, many people put it one one side or the other for their convenience.
Use the lap belt for the base and don't worry about not having LATCH.
The best technique I found is to sit on your knees on the seat/base with all your weight and pull, bounce and rock the seat, pulling hard and getting it tighter with each bounce. The base/seat should move less than 1" max.
We found getting Brita brand seats is better since they last longer (larger weight/height). Will save you the cost of 1 seat.
I recommend a mirror that goes on the outside headrest so you can see her. Use a rolled up blanket between the mirror and the headrest to get the angle right.
My son is 3 and is still in the middle, facing forward. It gives you a place to sit inside the car if it is raining or cold.
Hope this helps.
