Back window won't roll all the way down..
mizak82
Hi guys,
when I hold down the button on the FOB key to lower the rear window, it only cracks it open a few inches..
if I use the switch inside above the 4WD switch it rolls up and down no problem..
is there some sort of setting Im missing here?
thanks..
From the Owner's Manual ... Opening Back Window
"To open the back window, push the back window open switch of the transmitter for about 1 second. The window will fully open."
Tried it several ways. Press and hold. Just press. I get the beep and then it cracks the window down a few inches. Not down completely. It's weird.
Any chance you
have the window safety switch (on the arm rest) enabled?
Ok. Tried to do the reset.
When I use the switch inside. It only cracks it open, if I hold the down button. And if I hit the down button again it will roll all the way down. I checked the track. There isn't anything in the way.
So basically whether I use the key fob (have 2) or the inside down button it only cracks open. If I hit the key down again it does nothing but beep. If I hit the inside down button again it will roll down.
Any thoughts?
charlesz
