Bad double cardan?
DeclansDaddy
So I finally got to trying out the 4wd tonight on my build and I'm having some issues. In 4 low when I give it gas I have a clanking/banging noise coming from the driveshaft/transfer case area. It sounds like it's coming from the double cardan joint area. If I idle slowly up to speed it's fine. Just when I give it gas. In 4 high it does it but not nearly as bad. I'm guessing less torque from less gearing??? Sound like I need a new ball and spring setup to you guys?
H.Sikina
