Bad leak
99offroadrngr
After flushing my power steering system completely, my truck has developed a pretty bad leak. The leak was present before, but nowhere near as rapid as it is now. I'm guessing it's because the clean fluid is thinner than the gross stuff I drained out.
Coming from the inner tie rod where it meets the rack?
My pump is loud again because of it and I've had to keep filling the reservoir .
EC0911D2-CCE1-47A8-80A0-31F58B6AD232_zpsurmqvs6f.jpg~original
Did you use ATF? That stuff in the pic looks pretty clear. I believe power steering fluid is bad in our steering system.
I suppose ATF might come clear too, I don't know.
Considering how quick it leaks, I won't put up with it for long and luckily it's not my daily driver.
Is that rack comparable to OEM? I thought I've read that OEM is the way to go
Well I do like the lifetime warranty, kinda tough to beat.
I don't know what is preferred, oem or not on steering racks, I'll defer to someone else on that but if you want oem, here's one: https://www.amazon.com/Remanufactur...eywords=OEM+2001+toyota+4runner+steering+rack
A little pricier but oem usually is. Luck.
I had a leak this summer. After refilling the PS rez a few times with Maxlife ATF, the leak went away on its own.
I love a happy ending :cool:
It wouldn't hurt to try to use some stop leak product. If you are lucky, it may stop it, if not, you are only out 5 bucks or so.
Considering you are in MA, the old fluid may act as a good rust prohibitor. But do try the Maxlife...
All that rust......
True. I'll be going OEM with it and ordering tonight
That sway bar bushing is shot.
Sure is. The swaybar is coming off for good anyway
I may try it for the hell of it but I'm still just going to replace the rack. I'll do the lbjs while I'm at it
I'll give it a shot later
All that rust......
lol I'm surprised to have found a 3rd gen that has no frame rot or has been patched
I did use a power steering stop leak on mine and yes it did work. It lasted a few more months until the rack eventually did fail.
