• TAP is reportedly Out of Business Oct. 2022 per this thread.
Baja Designs LP4 Series - NEW Product Release
Baja Designs has release a NEW Version of their successful LP Series...
LP4 LED Lights in White and Amber
The Baja Designs LP4 LED Lights are the smallest variant in the LP Series line up but maintains
all of the power and features of its siblings, LP9 and LP6.
The LP4 features a total of 8,750 lumens and a 200° spread of useable LED light.
These LP4 LED Lights pump out 7,050 forward projecting lumens and 1,700 lumens of dedicated
peripheral lighting courtesy of our patented Integrated Peripheral Technology (IPT).
To keep your light performing at its highest potential, the LP4 integrates our proprietary Direct
Ducted Cooling (DDC) technology. This feature allows air to travel through the front of the housing,
over the rear heat sinks - drastically improving cooling capacity and performance.
With an white/amber day-time running light, the LP4 will fulfill all your lighting needs.
Specifications:
  • Forward Projecting Lumens: 7,050 Utilizing 4 LEDs
  • Forward Projecting Wattage/Amps: 60W / 6.5A
  • IPT Lumens: 1,700 Utilizing 4 LEDs
  • IPT Wattage/Amps: 15W / 1.0A
  • Backlight Wattage/Amps: 4.83W / 0.35A
  • Dimensions: 5.1" Height / 5.1" Width / 3.2" Depth
  • Weight: 2.8lbs
  • LED Life Expectancy: 49,930 Hours
  • Front Lens: Hardcoated Polycarbonate
  • Housing: Hard Anodized Machined Aluminum
  • Bezel: Billet Machined Aluminum
  • Hardware & Bracket Material: Stainless Steel
  • Exceeds MIL-STD810G (Mil-Spec Testing)
  • Built-In Overvoltage Protection
  • IP69K (Waterproof up to 9ft & Pressure Washable)
  • IK10 Compliant (Mechanical Impact Testing)
Baja Designs Features:
  • Satisfactions Guarantee – 30 Day Money Back
  • Guarantee
  • Limited Lifetime Warranty – Complete Purchase Protection
  • uService® – Replaceable Lenses And Optics
  • ClearView® – All The Light, Right Where You Need It.
  • MoistureBlock™ – Waterproof, Rain Proof, Submersible
  • CopperDrive® – Only LED Driven At 100%
  • 5000K Daylight – Less Driver Fatigue, Natural Color
Patterns:
Driving/Combo: Maximum trail coverage in a single light. The Driving/Combo pattern is equipped with both Wide Driving (42°) and the spot (6°) optics to provide you with a smooth blend of light for both near field applications and distance (Lighting Zone 3)
High Speed Spot: A longer and narrower 6° beam focus for illumination further down the trail or road. The Spot pattern is designed to be used in conjunction with additional Wide Driving and/or Driving/Combo beam lights. (Lighting Zone 4 & 5)
LP4 Spot, White - Part #290001
LP4 Spot, Amber - Part #290011
LP4 Driving/Combo, White - Part #290003
LP4 Driving/Combo, Amber - Part #290013
MSRP: $424.95
Online: $390.95
T4R: $373.96
For a Complete List of Options - Click Here
_
The All NEW LP4 Series is Finally Here!
Estimated Ship Date - 1/8/2020
Also Available in Pairs...
Part #297801, Spot
Part #297803, Driving/Combo
Part #297813, Amber Driving/Combo
MSRP: $849.95
Online: $781.95
Includes:
QTY (2) LP4 LED Light
QTY (1) Wiring Harness
When ordering online, use Promo Code "T4R" for added savings.
_
ghengiskhan
