baja designs Security Hardware Kit
Anyone know how these work? My light has a threaded bolt or stud coming out from the light body on each site of the light. Then it sits in the brackets and a nylock nut it tightened on each end. Not quite sure how this would work.
Anyone know the thread specs on the bolt/stud? Was thinking about just trying to order a security nut on amazon.
https://www.bajadesigns.com/products/onx6-s8-xl-xl-r-pro-sport-security-hardware-kit.asp
It replaces the threaded stud, I have the same kit on my light.
Thanks. How is that removed? I don't have the light down from the rig and it's been a while since I installed, but I don't remember them looking like they could be removed.
They either have an end that a Allen key can fit into. Or you can do the to bolts snugged up against each other trick to undo them.
the studs have a opening on the ends for allen key.
Much cheaper to buy the security screws elsewhere.
Planning to put in security torx on side, and the 2 pin on the other side hah.
delislerebecca
