Singtoe
I have been PM-ing with BigJohn about the Aisin hub conversion and an interesting point has been made.
The Tacoma lower ball joint is different then the 4runners.
I went and physically looked at them (on the trucks though) and the Tacoma's ball joint is beefier looking. Even the tie rod mount on the Tacoma is bigger. The nut that holds the tie rod end on to the ball joint is bigger. The Tacoma's nut is 22mm and the 4runner is 19mm. The rubber dust shield on the Tacoma is even more stout.
I think that converting over to Tacoma ball joints and tie rod ends might be cure to all these lower ball joint failures.
Mind you that I did not physically remove them and maybe a quick trip to a parts store so more accurate measurements of the ball and seat can be made.
Anybody work in parts store?
