"Base Camp" 2015 Superwhite TE Build Thread
Thanks for fixing the pictures, wow that's impressive work.
Love pizza cutters also!
Love the utility behind the floor you guys are coming up with.
Great job on the rear cargo floor system!
Did you ever install the Prinsu rack? I'm local and have done it before if you need a hand.
Looking forward to updates.
Custom Rear Cargo Area with L-Track Tie Downs and storage Flush when seats are folded. This has been my most used and favorite mod to the truck. Bomb proof and used almost daily.
Components used in build:
From local HW store:
1/2 inch hardwood plywood for platform and doors
2x4 pine plywood for 3 supports
Stainless 3/8 inch bolts washers and lock washers
From the Interwebs:
Concealed hinges for doors
Recessed handles
L-track logistic tie downs
Tie down l-track adjustable studs
First took measurements and cut 2x4 scrap from other projetcs to fit base. Lined up the outer 2x4 over the under body unibody frame so the tie down points pass through multiple layers of sheetmetal. Middle support is just through 1 sheet of sheet metal. Plan is to have studs over strongest part of body, then to have the L-Track tie down rails directly on top of the bolted down studs.
Then I got a sheet of 1/2 inch hardwood plywood and cut it down to size. Used pencil to mark the layout and cuts. There are two layers of ply in this design. The base layer is all one piece with the holes for the doors cut out, and then there is an upper layer that will be flush with the doors and the L-Track.
This is a detail of the bottom of the thing. It ended up being quite a complex shape to conform to the floor and make the most of the available space.
Here is the top with the rails and doors laying in place. I spent a lot of time thinking about clearances and anticipating the different locations Line-x would be sprayed so everything would be flush and tight (but not too tight) once finally assembled with Line-x
A final test fit in the truck and checking tolerances all around.
Detail of the countersunk doors to allow for the depth of added Line-x on both the doors and the frame.
Sprayed with Line-x. The guys working there thought I was legitimately crazy. But fact of the matter is my 2015 4runner has a higher payload than my 2010 tundra crewmax! Everything came together nicely!
Installed the hinges. I spent some time thinking about them and got them installed correctly the first time. That never happens!!!
Final pics in the truck. Everything's a little dusty.
After living with it now for a couple weeks I couldn't be happier. It's super secure, the tie downs work great! It's really nice to have some concealed storage and the 4 door system allows me to have gear in the back area and still get to one or more doors by moving things around vs 1 big door I originally planned.
I've had several inquiries about it. Feel free to borrow any or all of the design.
none of these photos are showing on my end. id love to see the build, im trying to figure out how i want to build out my cargo area.
From the Interwebs:
Recessed handles
Could you post new pictures of it? I can’t see them!! Or could you send them by PM? Thanks
This build is sick, sad to have found it so late but OP if you're still around I'd love to see these pics! Most of them don't seem to show for most of us anymore.
Also, anybody have a cheat sheet for dimensions or other design cues? I'll start figuring things out myself in the meantime, but of course the less work I have to do the better :)
Hey man, Im about to attempt to build this thanksgiving weekend. Have you started yet? I'm gonna be in oakland as well during that time.
