BaseRunners 1989 22RE Build thread
BaseRunner
Well hello fellow 1st generation owners, I just bought this beauty today 4/5/2013. It needs a new timing chain and it has some rust. I plan on sanding the rust off pretty good and using some rust treatment. Then I plan on plasti dipping the WHOLE ride black! Any suggestions by you guys for what else I should do with it would be greatly appreciated it! Oh and I have a 2000 3rd generation which is my daily driver, this 1st generation will be the weekend ride!
more pics
Boo plastidip, you need to bring that factory paint job back!
Lol man I wish I could do that, but I dont have the money to do that. Plus this is gonna be the weekend warrior, im going to be going mudding crawling and all that good stuff. So its gonna get all scratched up...plus Plasti dip is affordable lol. I dont know what to do about some of the rust though.
http://www.rustoleum.com/CBGProduct.asp?pid=367
Try this. Cheaper than plastidip, resists scratches nicely and has a cool sand paper like texture. With a light sanding first, it holds great.
Get a wire wheel and clean up the rust. Spray some por15, chassis saver or whatever your favorite rust treatment is on the rust. That will stop the spread of the rust. Stay away from plastidip. I haven't ever seen good results from it. I have never used it but anything that I have seen with plastidip on it has looked crappy and the paint has peeled after a very short time. If you're going to repaint it then use a rustoleum paint and make sure you do your prep work.
Either way you go, take lots of pics and post your progress!! Congrats on the new runner!!
RustOleum.com
Thats a interesting idea, thanks im gonna think about that.
Thanks man, and I appreciate the tip, Im going to try and get this rust off and think about what im going to go with. But first things first, I need to change the timing chain and have this baby up and running. Everyday I walk out of my house I look at it and get sad that its just sitting there and not being driven on a mud trail or something lol.
Just grab a grinder and saw zall and cut it all off. Wheel with whatever is left.
I think im gonna just sand the hell out of it and just treat it and spray over it. That will still keep the truck intact. Its not too much, the only considerable amount of rust is on the driver side by the back tire. Other then that its pretty good underneath and other places. But that spray you recommended might come in handy!
Sorry guys noob question here. I noticed my brake fluid is really really low! I was wondering would any type of brake fluid be good? or is there a special type of brake fluid for these classic runners?
After you get engine running, address the known issues with these classics, to name a couple:
  • Rear suspension sag,
  • Intermittent click-only starting issue,
  • Dim headlights because of thin wire and unnecessarily long current path, which also burdens dimmer switch with high current (not ideal, and as high as 17 amps with 55/100 bulbs)
Standard DOT-3 is good.
Thanks for the tips man! much appreciated!
I just went out to try to get my runner started. When I put the key in it wont start!!...the day I brought it home it started fine with no problems. Now I must say the day I brought it back I didnt know about the push button release for the ignition key so I just pulled it out of the ignition...did I mess something up? whats wrong with my runner??
It's either the starter relay or the starter solenoid itself. Some reading for you: http://www.toyota-4runner.org/class...x-intermittent-no-crank-22re.html#post1117438
Short story - turn the key to on, just before the crank position. Use a wire to jump your positive battery stud straight to the stud on the starter solenoid. If this starts your truck, then a) if your truck doesn't have a factory starter relay, do the fix I detailed in that thread, or b) if it does have a factory relay, follow the link to RADs fix.
If jumping the battery to the solenoid doesn't start the truck, then it's not a wiring issue, it'll be trouble in the solenoid or starter itself. Probably the solenoid, which can be rebuilt for just a couple bucks.
Thank you so much KidV!! I'm gonna try this and see what happens! I really appreciate it!!
I'm sure you already checked this but make sure your battery did not die. You said you did not turn the truck all the way off and pulled the key out. This could left the radio on until the battery died. Good luck
Actually I havent checked that yet. Now that my dad is back from work with my 3rd gen (he likes driving it better then his nissan frontier :lol: ) im gonna go jump it and see what happens. I hope to god its the battery because I dont feel like doing so much work on it lol. Thanks man!
WOOOHOOOOO after a few trys it started back up with a jump!! Thanks guys I really really appreciate yals input! Thats one less thing I have to worry about lol.
