SkidPalace
Member
Hi all,
I have a basic brake job question that maybe some of you can answer.
I recently installed new pads and rotors on my '00 4R and I have an odd sound/vibration coming from the new combo.
I installed the plain-jane Wearever rotors from Advance Auto with Wagner Thermoquiets. The installation went fairly well with the exception of a major struggle to remove the rusted pad retaining pins.
I was suprised to hear that the pads come with no anti-squeal grease and no shims. The guys from two shops said the ceramic Thermoquiets don't need either. Does this sound normal?
Also, I am getting a slight vibration when stopping a low speed with the new pads. I can only describe it as a buzz or a hum if that makes sense. It seems to go away if the braking gets more frequent/severe. I am assuming the pads may be heating up and the problem is going away.
Mind you, I only drove the truck twice so far with the new pads for a total of about 10 miles. The hone marks are still clearly visible in the rotors.
One thing I realize I may have to get back into the calipers for is that I didn't use grease anywhere on the install. I ran out of daylight and was rushing to finish up. In retrospect, the pads went in tight due to the channels being a bit rusted. I assume I should pull the pads and scrape the channels so that the pads slide in without resistance, than grease the hell out of the channels and pad retaining pins?
