BASS600 install in 3rd Gen
craigfr
I recently replaced my front 6 1/2s with JBLs. I thought this would add a little on the lower end, but it did not. The new speakers were much more clear, but lacked the bottom end even the stock speakers had.
Clearly I needed more bass. After looking around, I found what is called a "low-profile" subwoofer and amp unit that fits underneath the driver or passengers seat. This worked perfect, as I didn't have to give up any cargo space. There are several models, but I chose the Bass600 because I'm broke and got a sweet deal on it ($72 shipped from amazon). Plus it got good reviews, and is smaller than the infinity basslink (my second choice).
Below is a picture of the final install. It's not outrageously loud, but it fills in all the lows and more. I only turn it up about halfway, but it can take a lot more juice. Below are a few pics of the install.
Unless you're looking for it, it's very hard to see, and doesn't get in the way of anything.
Here's how I installed it:
First, looking at the 4Runner basic stereo wiring harness diagram, I figured out what to splice to hook into the bass600 high level inputs.
For the install itself, I started by taking off the main control panel. This is very straightforward, just make sure to detach ALL of the harnesses behind it.
Now, one by one, I spliced each 4runner stereo harness wire required and re-attached them, adding the bass600 wire into the crimp. This is not the best way to do it, but it's what I had lying around to work with.
Finally finished! Here it is after every wire required (6 total) was spliced and reattached with the bass600 wire.
Here is a technical diagram showing how I ran the wire down beside the shifter and to the floor beneath my seat.
The other wire required to attach is a ground wire, which I hooked to the bolt holding in the E-Brake sensor.
The BASS600 unit itself slips in underneath the driver side seat from the back. I used one of the included pieces of velcro (just the non-fuzzy one) and put it on the back of the unit so it wouldn't slide on the carpet. I attached the remote level dial on top of the unit with 3M mounting tape.
Cheers
Craig
I am concerned the first time some short guy moves your driver's seat all the way up it will cut your wiring. Like when you take it to get tires or a battery replaced or whatever.
I'm no car stereo expert and not pretending to be, but I would think a better alternative would be to tuck under the seat track. Wiring loom is good protection for those thin gauge wires. Personally I would have used a thicker gauge for the power and ground wires.
Not trying to dis on your efforts sir. I am glad to hear the review of the Boss Bass600 and am looking for a similarly priced unit of that size to fit in my 89 MR2 under the seat as well. I can tell you however the Infinity Basslink sounds real good out back in our Runners but of course eats up some space for cargo and my dog. And costs about 3x what yo paid for your Boss unit.
I share your brokeness....
