TheDurk
Elite Member
First off, let me say thank you to everyone assisting with this. I understand the concepts of electrical, just not too good at troubleshooting.
[MENTION=10169]TheDurk[/MENTION]: no Canuck model, no daytimes.
I found the EA1 plug.
I have continuity from EA1, terminal #1 to wire #2 @ the alternator.
I have continuity from EA1, terminal #2 to wire #1 @ the alternator.
I have continuity upstream from EA1, terminal #4 to the fuse.
I DO NOT have continuity DOWNSTREAM from EA1, terminal #4 to wire #3 @ the alternator. Looks like maybe I've got a faulty splice.. Or connector.
I think we may have found the culprit! Just need a warm place to pull in and repair it. ...Also need to find my damn heat gun so I can put heat shrink on again.
Anyone know how I can test the terminals inside the plug to narrow it down to my sh*tty splice job? :redbrick:
I'll update ya'll as soon as I make the repair.
Well, assuming issue is plug or splice, you will need to break the splice either way. And once you break it, testing the plug is easy. So break the splice.
