Battery change: 2006
mole177
Anyone change their battery on an 06 yet?
I wonder when mine will die...
I thought batteries should last about 4 years...
but my rig still fires up no prob.
There was a thread on battery life about a month or so ago. It seems it is not unusual for these batteries to last 6-8 years. I still have the original battery in my '03.
anyone change their battery on an 06 yet?
But my rig still fires up no prob.
i just traded in a 04 camry that had the factory panasonic battery. 6 years and never a problem unless i left the aftermarket fogs on of course. User error. Now i have an 07 runner with factory battery and it seems to be doiing fine.
My 02 camry had the original battery in it for 8 years. I changed it before a long road trip but it started the car in the cold winter, just like a new one would.
Who makes Panasonic batteries anyway? Is it actually made by Panasonic themselves. The reason I'm asking, when it comes time to change it, i'm getting another Panasonic one.
My rule is 5 or 6 years to a battery, then I replace it. Probably I am missing out on a few years of use but a dead battery in new model cars especially is a real hassle.
I tend to time replacing a battery in the fall, before the cold weather sets in, unless it completely fails before then. I have found that most of the time, even a marginal battery will work in warm weather, but the first cold snap will push them over the edge.
I just replaced the original battery in my '04. The original battery was still working fine, but I do a lot of traveling and go on a lot of ski trips in the winter and I figured that I'd rather be safe than sorry, so I installed a new battery.
I was curious to see how long my original battery would last, but I guess I'll never know. I don't think I've ever had a battery last more than 4 years, so the fact that my original battery was still going strong after nearly 7 years made me think it was on borrowed time.
Does anyone want a slightly used 7-year-old Panasonic battery?:wow2:
My ole battery died in Sep '10. I could have gotten more life out of it but I would leave the truck parked 3 months at a time without disconnecting the battery.
There's nothing set in concrete regarding battery time-to-failure. I've seen some batteries last 2 years and others beyond 8. It depends on the design, manufacturing, driving style, environmental conditions, etc. Frequent highway driving will keep a battery nearly fully charged while mostly city driving will only allow the battery to maintain 50-80% charge which can drasticaly reduce a batteries service life.
Plus, some batteries will simply lose capacity over time while others will pass a capacity test one day and fail catastrophically the next.
If your battery is getting up in age, have it load tested. If it passes but still worries you, replace it.
I've had some OE Panasonic batteries in my previous Toyotas last beyond 8 years. But I did begin to carry jumper cables at about 6 years just in case. I was determined to see how long the battery would last and chickened out at 8 years each time.
I'm VERY hard on batteries. I live 3 miles from where I work and my 4Runner spends 95% of its time on back roads. Short trips are normal for my 4Runner. I'm lucky to get 3 years (4 maximum) from the batteries in all of my cars over the years. For whatever reason, the OEM battery on my 4Runner was still going strong after 7 years. But I still replaced it because I figured it can't possibly last much longer.
Can anyone find an expiration date on the battery? ANy car I had before this one always had some sticker on the battery indicating the expected end-of-life date.
What did you replace your battery with? It is time for me to replace mine, and I am looking for a good replacement recommendation.
Batteries are a roll of the dice.
Our '03 T4R SE V8 literally just had the original Panasonic battery replaced after the cold crank test said it was way below the acceptable level. 8 years.
Out '08 also just had the original battery replaced due to a very very low cold crank test, so that goes to show you that the batteries can be a funny thing.
Maybe the cold crank test is really the roll of the dice. Our company van was tested and we were told that the battery had low cold cranking amps. That was more than 3 years ago and the battery still works fine.
Unfortunately the OEM Panasonic batteries are not available stateside, Japan only. Toyota sells replacement batteries with similar specs but they are not Panasonic. I have an '09 so it will be a loooong time before I start thinking about replacing it.
I hated to do it, but I just got a new one a few days ago on my 05. It was going on 7 years, but Ive got some long trips coming up and didnt want to risk being stranded.
The OEM Panasonic still seemed to be going strong though.
