Anyone change their battery on an 06 yet?
I wonder when mine will die...
I thought batteries should last about 4 years...
but my rig still fires up no prob.
anyone change their battery on an 06 yet?
But my rig still fires up no prob.
My rule is 5 or 6 years to a battery, then I replace it. Probably I am missing out on a few years of use but a dead battery in new model cars especially is a real hassle.
There's nothing set in concrete regarding battery time-to-failure. I've seen some batteries last 2 years and others beyond 8. It depends on the design, manufacturing, driving style, environmental conditions, etc. Frequent highway driving will keep a battery nearly fully charged while mostly city driving will only allow the battery to maintain 50-80% charge which can drasticaly reduce a batteries service life.
Plus, some batteries will simply lose capacity over time while others will pass a capacity test one day and fail catastrophically the next.
If your battery is getting up in age, have it load tested. If it passes but still worries you, replace it.
I've had some OE Panasonic batteries in my previous Toyotas last beyond 8 years. But I did begin to carry jumper cables at about 6 years just in case. I was determined to see how long the battery would last and chickened out at 8 years each time.
I've 2004 with original Panasonic battery. It's still going strong.
I'm VERY hard on batteries. I live 3 miles from where I work and my 4Runner spends 95% of its time on back roads. Short trips are normal for my 4Runner. I'm lucky to get 3 years (4 maximum) from the batteries in all of my cars over the years. For whatever reason, the OEM battery on my 4Runner was still going strong after 7 years. But I still replaced it because I figured it can't possibly last much longer.
Batteries are a roll of the dice.
Our '03 T4R SE V8 literally just had the original Panasonic battery replaced after the cold crank test said it was way below the acceptable level. 8 years.
Out '08 also just had the original battery replaced due to a very very low cold crank test, so that goes to show you that the batteries can be a funny thing.
