Might you have bumped the switch and put the window down just a bit? It has happened to me and if the rear window is down even a bit the wiper won't work...
The "AUTO" light in your driver's window switch should be blinking, indicating that it needs to be reset for the auto function to work. Open it part way, then close and hold for a second to reset. Same with the rear window. If you have a sunroof it might need the same. This is somewhere in the owner's manual.
